Grove - Air Quality Sensor v1.3
This sensor is designed for comprehensive monitor over indoor air condition. It's responsive to a wide scope of harmful gases, as carbon monoxide, alcohol, acetone, thinner, formaldehyde and so on. Due to the measuring mechanism, this sensor can't output specific data to describe target gases' concentrations quantitatively. But it's still competent enough to be used in applications that require only qualitative results, like auto refresher sprayers and auto air cycling systems.
We've released the [Seeed Gas Sensor Selection Guide](https://wiki.seeedstudio.com/Sensor_gas/), it will help you choose the gas sensor that best suits your needs.
Version
Product VersionChangesReleased Date
Grove - Air Quality Sensor v1.3InitialMay 2016
  • Responsive to a wide scope of target gases
  • Cost efficient
  • Durable
  • Compatible with 5V and 3.3V
caution
1. Requires relatively clean air as an initial condition.
2. Long time exposure to highly polluted air can significantly weaken its sensitivity.
3. Coffre-fort et armoire forte:
Platforms Supported
ArduinoRaspberry Pi
caution
Getting Started
note
If this is the first time you work with Arduino, we firmly recommend you to see [Getting Started with Arduino](https://wiki.seeedstudio.com/Getting_Started_with_Arduino/) before the start.
Play With Arduino
Demonstration
As described in Introduction, this sensor performs better in providing qualitative results over a wide scope of target gases. In this demo, we will define 4 statuses for reference in the '.cpp' file. They are:
  • a. air fresh -- indicating a good air condition
  • b. low pollution -- indicating a rather low concentration of target gases exist.
  • c. high pollution(without "Force signal active" message printed on serial monitor) -- you should be aware of the pollution level and consider if some measures could be taken.
  • d. high pollution(with "Force signal active" message printed on serial monitor) -- instant measures should be taken to improve the air quality.
We encapsulated the decision structure in a '.cpp' file. You can find information there on how to modify the thresholds.
Let's try it out!
Hardware
  • Step 1. Prepare the below stuffs:
Seeeduino V4.2Base ShieldGrove - Air Quality Sensor
Get One NowGet One NowGet One Now
  • Step 2. Connect Grove - Air Quality Sensor to port A0 of Grove-Base Shield.
  • Step 3. Plug Grove - Base Shield into Seeeduino.
  • Step 4. Connect Seeeduino to PC via a USB cable.
note
If we don't have Grove Base Shield, We also can directly connect Grove - Air Quality Sensor to Seeeduino as below.
SeeeduinoGrove - Air Quality Sensor
5VRed
GNDBlack
Not ConenctedWhite
A0Yellow
Software
Grove_Air_Quality_Sensor.ino
Demo for Grove - Air Quality Sensor.
Copyright (c) 2019 seeed technology inc.
Author : Lets Blu
Created Time : Jan 2019
Modified Time:
The MIT License (MIT)
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
#include "Air_Quality_Sensor.h"
AirQualitySensor sensor(A0);
void setup(void) {
Serial.begin(9600);
while (!Serial);
Serial.println("Waiting sensor to init...");
delay(20000);
if (sensor.init()) {
Serial.println("Sensor ready.");
} else {
Serial.println("Sensor ERROR!");
void loop(void) {
int quality = sensor.slope();
Serial.print("Sensor value: ");
Serial.println(sensor.getValue());
if (quality == AirQualitySensor::FORCE_SIGNAL) {
Serial.println("High pollution! Force signal active.");
} else if (quality == AirQualitySensor::HIGH_POLLUTION) {
Serial.println("High pollution!");
} else if (quality == AirQualitySensor::LOW_POLLUTION) {
Serial.println("Low pollution!");
} else if (quality == AirQualitySensor::FRESH_AIR) {
Serial.println("Fresh air.");
  • Step 4. We will see the distance display on terminal as below.
Sensor ready.
Sensor value: 48
Fresh air.
Sensor value: 51
Fresh air.
Sensor value: 49
Fresh air.
Sensor value: 48
Fresh air.
Sensor value: 48
Fresh air.
Sensor value: 48
Fresh air.
To adjust the thresholds and indicating messages, refer to the decision structure below in the .cpp file.
int AirQualitySensor::slope(void) {
_lastVoltage = _currentVoltage;
_currentVoltage = analogRead(_pin);
_voltageSum += _currentVoltage;
_volSumCount += 1;
updateStandardVoltage();
if (_currentVoltage - _lastVoltage > 400 || _currentVoltage > 700) {
return AirQualitySensor::FORCE_SIGNAL;
else if ((_currentVoltage - _lastVoltage > 400 && _currentVoltage < 700)
|| _currentVoltage - _standardVoltage > 150) {
return AirQualitySensor::HIGH_POLLUTION;
else if ((_currentVoltage - _lastVoltage > 200 && _currentVoltage < 700)
|| _currentVoltage - _standardVoltage > 50) {
return AirQualitySensor::LOW_POLLUTION;
else {
return AirQualitySensor::FRESH_AIR;
return -1;
Play with Codecraft
Hardware
Step 1. Connect a Grove - Air Quality Sensor to port A0 of a Base Shield.
Step 2. Plug the Base Shield to your Seeeduino/Arduino.
Step 3. Link Seeeduino/Arduino to your PC via an USB cable.
Software
Step 1. Open Codecraft, add Arduino support, and drag a main procedure to working area.
note
If this is your first time using Codecraft, see also [Guide for Codecraft using Arduino](https://wiki.seeedstudio.com/Guide_for_Codecraft_using_Arduino/).
Step 2. Drag blocks as picture below or open the cdc file which can be downloaded at the end of this page.
Upload the program to your Arduino/Seeeduino.
When the code finishes uploaded, you will see air quality in the Serial Monitor.
Play With Raspberry Pi (With Grove Base Hat for Raspberry Pi)
Hardware
  • Step 1. Things used in this project:
Raspberry piGrove Base Hat for RasPiGrove - Air Quality Sensor
Get ONE NowGet ONE NowGet ONE Now
  • Step 2. Plug the Grove Base Hat into Raspberry Pi.
  • Step 3. Connect the Grove - Air Quality Sensor to the A0 port of the Base Hat.
  • Step 4. Connect the Raspberry Pi to PC through USB cable.
Software
attention
 If you are using **Raspberry Pi with Raspberrypi OS >= Bullseye**, you have to use this command line **only with Python3**.
  • Step 1. Follow Setting Software to configure the development environment.
  • Step 2. Download the source file by cloning the grove.py library.
cd ~
  • Step 3. Excute below command to run the code.
cd grove.py/grove
python3 grove_air_quality_sensor_v1_3.py 0
Following is the grove_air_quality_sensor_v1_3.py code.
import math
import sys
import time
from grove.adc import ADC
class GroveAirQualitySensor:
def __init__(self, channel):
self.channel = channel
self.adc = ADC()
@property
def value(self):
return self.adc.read(self.channel)
Grove = GroveAirQualitySensor
def main():
if len(sys.argv) < 2:
print('Usage: {} adc_channel'.format(sys.argv[0]))
sys.exit(1)
sensor = GroveAirQualitySensor(int(sys.argv[1]))
print('Detecting ...')
while True:
value = sensor.value
if value > 100:
print("{}, High Pollution.".format(value))
else:
print("{}, Air Quality OK.".format(value))
time.sleep(.1)
if __name__ == '__main__':
main()
success
If everything goes well, you will be able to see the following result:
pi@raspberrypi:~/grove.py/grove $ python3 grove_air_quality_sensor_v1_3.py 0
Detecting ...
138, High Pollution.
139, High Pollution.
140, High Pollution.
141, High Pollution.
File "grove_air_quality_sensor_v1_3.py", line 71, in <module>
main()
File "grove_air_quality_sensor_v1_3.py", line 68, in main
time.sleep(.1)
KeyboardInterrupt
You can use this sensor to detect the air quality. Press ++ctrl+c++ to quit.
note
    You may have noticed that for the analog port, the silkscreen pin number is something like **A1, A0**, however in the command we use parameter **0** and **1**, just the same as the digital port. So please make sure you plug the module into the correct port, otherwise, there may be pin conflicts.
Play With Raspberry Pi(with GrovePi_Plus)
Hardware
Raspberry piGrovePi_PlusGrove - Air Quality Sensor
  • Step 2. Plug the GrovePi_Plus into Raspberry.
  • Step 3. Connect Grove-MOSFET ranger to A0 port of GrovePi_Plus.
  • Step 4. Connect the Raspberry to PC through USB cable.
Software
  • Step 1. Navigate to the demos' directory:
  • Step 2. To see the code
nano grove_air_quality_sensor.py   # "Ctrl+x" to exit #
import time
import grovepi
# Connect the Grove Air Quality Sensor to analog port A0
# SIG,NC,VCC,GND
air_sensor = 0
grovepi.pinMode(air_sensor,"INPUT")
while True:
try:
# Get sensor value
sensor_value = grovepi.analogRead(air_sensor)
if sensor_value > 700:
print "High pollution"
elif sensor_value > 300:
print "Low pollution"
else:
print "Air fresh"
print "sensor_value =", sensor_value
time.sleep(.5)
except IOError:
print "Error"
  • Step 3. Run the demo.
sudo python grove_air_quality_sensor.py
  • Step 4. We will see the output display on terminal as below.
Schematic Online Viewer
Projects
SPCPM (Solar Powered City Pollution Monitor): Low maintenance, high output air pollution, sound pollution that put throughout the city without wiring.
A website to see the environment data around you:
Home Control Center using BeagleBone Green Wireless:
